nightvision
- Joined
- Mar 7, 2004
- 252
Hi all,<br /><br />A couple questions <br /><br />a. After a day of boating, do you typically idle the engine to cool it down before retrieving your boat? If so, at what RPM would you idle at? <br /><br />b. Do you remove the drain plug when you get the boat out of the water and keep it open as you drive home or do you open it at home and raise the trailer jack. <br /><br />c. When I get home, I usually wash my boat down. Today, I remove the ram plugs and lower the stern drive and saw water coming out. Is this a necessary step that I should do every time? I do hear that you should store the boat with the stern drive down. I have an Mercruiser 3L with an Alpha 1. <br /><br /><br />Thanks.
