phoenixgold2100
Thread starter- Joined
- Feb 3, 2013
- 154
I have a 99 johnson 150 and the alarm goes on when the key is turned on and will not shut off (engine not running) so I know it's not an over heat issue. I disconnected the tan wire from the alarm and it kills alarm but when key is first turned the alarm has a dying chirp sound coming from it then stops. Is my alarm bad or is my tan wire shorted to ground and if so how would i go about finding it. I know they short to ground when they over heat but is there a reset after they do that?
Question 2> My fuel gauge doesn't work, I have confirmed the wiring is correct by touching the wires together at the sender spiking the gauge, I removed the sender and when I move the arm manually it moves the fuel gauge so I assume the float is not floating in the fuel. I am going to replace the sender but when replacing do i just get one with the same length float arm? (mine has no names on it as far as i can see)
Question 3> My tach doesn't work as well as my trim gauge all have power and ground according to the test light i hooked to the posts on the back of the gauges. I have traced wires to the trim sender white and tan and it seems to be correctly wired trim sender bad? I have traced the gray wire back to the rectifier and it seems right bad rectifier? Boat sat for a looong time from what I can tell do these things sieze up from sitting? Thanks.
