Bog - rpm restricted after 15 minutes
Bruce1983
All,
I have done some searching on the site but I am limited as I am accessing the Internet via cell network. Hope you can help me out.
I have a 88 mercruiser 4.3 with mechanical fuel pump and 2 barrel carb. I can run for about 10-15 minutes cruising at 3600 rpm and then it starts to bog. If I don't drop the throttle back it has stalled, but if I do I can keep cruising around 3000 rpm for as long as I want (at least 25 minutes anyway to get back home).
If I drop to idle for a minute or two I can get back to 3600-4000 for a minute or two until it bogs again.
I replaced the pump filter and carb inlet filter, checked the line into the tank and the vent line which seem fine.
Thanks for any help.
HT32BSX115
Re: Bog - rpm restricted after 15 minutes
Howdy,
It sure sounds like a fuel delivery problem.
If the filter is good and the vent is not plugged, you may have a plugged anti-siphon valve or the fuel pick-up screen in the tank is partially blocked with debris.
180shabah
I agree, start at the tank and work your way through...
Bruce1983
Thanks for the feedback. I pulled the tube out of the tank and there is no screen on the bottom. It doesn't appear to be an anti siphon valve either .... Unless it is contained within the tube or the 90 fitting??
jerryjerry05
Check the distributor advance.Points set right?
Fuel restriction?keep looking.
Check coil once you get it running,If it gets too hot to touch,it's bad.J
180shabah
A/S valve typically is screwed INTO the 90* fitting on the tank. Externally it just looks like a FPT to barbed fitting, but on the inside there is a one way check valve.
180shabah
'88 shouldn't have points.
superbenk
You can get a 1/4" NPT hose fitting for a compressor hose at an auto or hardware store and temporarily replace the anti-siphon to see if it helps (fixed my same issue & saved our vacation). I'll be ordering a new anti-siphon valve when we get home. You may also be developing a vacuum in the tank.
superbenk
You can probably test for a vacuum situation by loosening the gas cap when you are having your bogging issues. Should clear up I that's where the problem is.
Alpheus
You may want to check your fuel pressure also...
a70eliminator
I have heard although rare that a tightly sealed engine compartment can actually starve the engine for air, make sure there are no restrictions in the fresh air supplys, exhaust leaks make matters worse, rare but worth a mention if everything else has been ruled out.
joenapier
Check also your fuel / water separator filter. If the paper is loaded with water, it will restrict ful flow. Change it once a year.
