Reggie08
Thread starter- Joined
- Mar 31, 2008
- 243
I'm in the break-in period on my 85' Rude 90hp so I'm using a 25:1 mix (recommended since I'm not using the VRO tank) Ever since adding the extra oil, it seems to not want to run well in the mid-range for power (half to 2/3 throttle). I initially thought it was a spark problem, but checked for spark on all 4 cylinders and it's good. So I thought it was the 115hp high speed jets I installed (over-sized cylinders) and maybe it was getting too much fuel, but put the 90hp jets back in with the same results.
If I stay into the throttle, it eventually comes out of it then seems to run pretty good. The very first trip we took with the motor though, I was using 50:1 and it didn't have this problem.
Is the added oil causing the motor to want to bog down a bit? Or is there something I need to check? Carbs are cleaned and the floats are set properly. Did a lync-n-sync (though I may re-check it) and set the WOT timing per J.Reeves' method in the FAQ's. Everything looks good, just seems to not want to run like it did the first time.
