i have a 110hp v4 johnson (1989). I have removed, AND CLEANED THE FUEL TANK . i CHANGED THE PICKUP TUBE AND ALL THE HOSES BETWEEN THE TANK AND THE MOTOR. I TOOK OUT THE ANTISIPHON VALVE. I PUT IN A NEW VRO PUMP AND PLUGS. I INSTALLED A NEW FUEL FILTER AND WATER SEPERATOR.PROBLEM : WHEN I GET TO ABOUT 3 GALS OF FUEL IN THE TANK , IT REFUSES TO ACCELERATE. (I EMPTIED OUT THE CARBS AS WELL. ) SHOULD THE BULB BE HARD AT ALL TIMES ? MINES ABOUT 1/2 WAY FULL IT SEEMS. I INSTALLED A LITTLE LONGER PICKUP TUBE IN HOPES THATS THE PROBLEM. WHEN I FILL UP THE TANK IT SEEMS TO BE OK AGAIN. LIKE I SAID , AFTER ABOUT 3 HOURS IT GETS DOWN TO ABOUT 3 GALS LEFT IN THE TANK(18 GAL TANK) AND THE PROBLEM IS THERE.I THINK IT WAS THE PICKUP TUBE NOT GETTING ENOUGH FUEL. WHAT DO YOU FOLKS THINK ? FRUSTRATED.....SKIP (TANKS
