BOLT found in bilge - need help identifying please
Froeman
I have a 2008 Larson 180 with a 3.0L Volvo Penta (GL?) motor. SX outdrive. There are 53 hours on the boat. I found this bolt lying in my bilge a few days ago. I only had time for a quick visual inspection, but I can't see any obvious places where a bolt is missing. The boat runs fine (as far as I can tell).
The bolt is 2.5" long.
CAN SOMEONE PLEASE HELP guide me where to check?
Thanks!
Re: BOLT found in bilge - need help identifying please
Looks like the 3812255 Flange Screw from the circulating pump pulley.
Don S
What is the diameter of the bolt?
Froeman
Agree it looks a LOT like those screws, however, all 4 of them are present in the motor... are these used anywhere else in the motor?
aerobat
i think you will find these bolts in many places around the pulleys of the alternator, circulating pump and the according mounting brackets - i would look here carefully . i do not think such bolts are used in the alterntor or flywheelcover area .
it might also be the previous owner changed a part and used new bolts and now you found an old one in the bilge.
not an easy question where exactly this bolt is from .
Froeman
Thanks everyone... the main thing I'm worried about is that the bolt fell out of the motor block somewhere and it is a key piece of holding everything together. Wouldnt' want a catastrophic failure out on the water. I'll re-check the pulleys etc. and try to snap a photo or two to post.
Froeman
I think I found it. Seems to be part of the pully bracket assembly.. found another piece laying on the ground as well. See photo. Agreed? Thank you all again.
Don S
Is that the spacer (in your hand lower left of photo) that goes in that gap?
Froeman
Yes Don, I dug up an old photo of the motor and that bolt & spacer are there. MYSTERY SOLVED! THANKS EVERYONE!!
