Re: Bolt Torque question
While that's correct, it is very likely your torque wrench will be very inaccurate at that setting. Normally, they go way out at their lower settings.<br />So try to buy or borrow an inch-lb reading wrench. I never use my ft/lb wrench for the range my inch/lb reading wrench covers (about 240inch/lbs - 20ft/lbs). The big one is deadly accurate at 25-100ft/lbs, but when set to 15ft/lbs it actually torques to 19ft/lbs.
