LimeyGuinea
Thread starter- Joined
- Jul 16, 2012
- 5
Hello all! I have a 1988 Johnson VRO (dont hate!) 225hp V6 outboard on my 24 ft. walk around. I have some knowledge of the mechanics of this motor and have my service manual but am in no way an expert! I have emailed my problem to several mechanics, and no one will respond! Any help is appreciated...
Recently while out, the motor started sounding horrible and seemed as if the timing was off. I took the cover off to find some bolts and the bracket pictured below laying on the block. I believe they came from the armature plate. please correct me if i am wrong, i have posted a picture of where they came from also. I replaced them using some loctite, but only used the weak blue stuff. I also did NOT remove the flywheel when i did this so im sure the torque was not as much as it should have been. Started her up, and she sounded better then ever! any previous sputters, idle stalls, etc were gone!
However, as boating goes, this lasted for an hour, then went back to the same sound as before... Opened the cover to find the same bolts and bracket vibrated out again! The holes dont appear to be stripped, the bolts tighten down and are not worn, and were clean.
I replaced the bolts again using red, high heat loctite, and used better tools to tighten them down good. Again, i didnt remove the flywheel as i am trying to prevent any more problems which might come from doing so! I havent started it yet, wanted to give a good 48 hours for the loctite to cure. I am hoping this keeps them in place.
Is this something that has happened to anyone else? Does anyone have a better solution? Also, i have a puller and proper tools to remove the flywheel, is this something fairly simple that i will be able to do with the boat still in my slip? Thanks for any help...
Matty
The Limey Guinea
Matty
The Limey Guinea
