LimeyGuinea
Thread starter- Joined
- Jul 16, 2012
- 5
Hello all! I have a 1988 Johnson VRO (dont hate!) 225hp V6 outboard (powerhead replaced 5 years ago, lower unit replaced last season) on my 24 ft. walk around. I have some knowledge of the mechanics of this motor and have my service manual but am in no way an expert! I have emailed my problem to several mechanics, and no one seems to have a clue... I found some answers from someone on here which was helpful, but have some more info... Please take a minute to read and respond if you have ideas! Any help is appreciated...
Recently while out, the motor started sounding horrible and seemed as if the timing was off. I took the cover off to find some bolts and the bracket pictured below laying on the block. The bolts came out of the upper bearing housing. I had a reputable mechanic pick up the boat, and paid $2,000 to have him replace the bolts, stator, timing base, armature, upper bearings and flywheel magnetos. Got the boat back, went out for a half hour, and the same thing happened again leaving me stranded on the water.
After some nice happy calls to the pre-paid mechanic, (scarcasm!!) he said he used red, high heat loctite, locknuts, etc, bay tested the boat and everything was fine... seems like he is trying to say i did something wrong... Got an email from him today saying he removed the lower unit and now there is endplay in the crank...
My Questions:
Has this ever happened to anyone else?
What exactly does endplay in the crankshaft mean?
Am i being screwed over here?
does this mean my season and motor is done?
Thanks for the input!
My Questions:
