Bonding wire to ground on Mercrusier
tank1949
"Dingbat" has provided some information but I am still not clear if I should do this. I am refurbishing a 1986 Sea Ray Amberjack.The Amberjack has 2 MC bravo/stroker ODs/motors. Aluminum OD with SS props... I have replaced all anodes, including the heat exchanger's. In examining or replacing all wires or lugs, I noticed former owner or SR had connected ss bow rail, aluminum top frame, gas filler necks, gas tanks to a single bus bar on my transom via 8 gauge green coated wires. They are not Daisy Chained!
The boat is a salt water boat but never stored wet. I assume this is why Sea Ray attached so many bonding connectors on just about all salt water exposed metals?
I have since replaced transom and re-lugged all wire ends or replaced with new wires. I assume this bus is the bonding bus. There was a smaller (maybe 12 gauge black wire connected the bonding bus to one of the motor blocks.
Both blocks connect to each other via a 2-4 gauge (assume) black wire. Both blocks also are connected to negative battery posts via 2-4 gauge black wires.
I also have added a bronze saltwater pickup thru hull that (below water line) is connected to a piece of 1/4" ss plate near the stern. 3/8" bolts connect the ss plate to the bottom of boat's hull. (definitely dissimilar metals) A plate/bolt is connected to bonding bus via an 8 gauge green wire.
Should the black ground wire going from block to the bonding bus be heavier gauge? THX!
