Hello,
I have a 1994 30 hp Merc outboard, 2 cylinder, with oil injection. It looses the bottom cylinder at idle and surges. If I turn out the mixture screw to about 5 turns, the cylinder fires and the engine runs normal. But I know 5 turn is too much. It sounds like an air leak. I pulled off the reed plate, the valves look OK, the check ball in the check valve for the bottom cylinder disappeared and I replaced it, hoping that was my problem. Put it back together, and still does the same thing. Anyone have any other suggestions? Should I start ripping it apart to look at the bottom crank seal? Or is there something else?
Thanx for your help and have a great day,
Rob.
Rob.
