bottom paint
fishingman220
The paint on the bottom of my boat is very old and is comming off, it is one layer and is rubbed off where it rubs the trailer, is there anyway to tak it all off without messing up the gel coat????
tashasdaddy
Re: bottom paint
the only way off is sanding. and recoating.
KurtG
Re: bottom paint
You can try the chemical strippers too or have it soda blasted.
I've been working on removing the bottom paint for a long time with strippers, scrubbing, and wet sanding and feel like a snail. I should have taken it and had it soda blasted (given what I have in it now in stripping supplies), but was working on the trailer too.
I've used several different chemical strippers and wet sanded too. None of them worked very good, so am using the cheaper ones that are safe on fiberglass.
I'm at the point of having most of the gel exposed and can say that ~80% of mine can be restored to original gel by removal and wetsanding and 20% along the keel is going to need repairs (dings and a few pimple size blisters).
fishingman220
Re: bottom paint
with soda blasting, do you have to do anything to the hull after blasting other than waxing??? or does it have to have new gel coat???
