Blueghost924
Thread starter- Joined
- Sep 19, 2013
- 250
Hi, I'm new to IBoats and kinda new to boat ownership. I recently bought a 1987 Renken 21' boat that has the 3.7L Mercruiser inboard installed still. From all looks, the block is pretty well intact. The head and valve cover are attached. The intake and exhausts of the head are rusty. Also, the exhaust manifold came with the boat, but was not attached.
My big question is it worth trying to salvage and bring the current engine installed back to life? Or would it be better to just install a re manufactured motor? If I decide to bring the engine back to life, I am going to have to buy, as a minimum, an alternator, spark plugs/wires, distributor, intake manifold and carburetor. To help in the decision, I'm considering trying to turn the motor over and check compression. I'm not sure how to turn it over by hand - is there a way to do this? I'm also considering seeing if the starter/solenoid are good as well. Prior to turning over, I'm also thinking about spraying some of my Seadoo Bombadier spray lube down each spark plug hole. Also, I've checked the oil level, and it's good (although it's probably old).
I would guess that the engine hasn't been run in about a year.
Attached is a picture that shows it's overall condition. Thoughts?View attachment 212532
