Re: Bought a fixer upper *pictures added*
alright, i feel i got a little accomplished
changed plugs
added seafoam
changed fuel filter
i did not take the carb apart, i did spray some in the butterfly
and there is a hose running to the side that i took off and sprayed some inside the carb.
seems to idle a little better but i now believe the problem is elsewhere...
at the motor end of the control cables there is the selector? shift linkage? dont know what it is called. i put it in drive and its putt putt... i push the selector just a little bit and away we go.
here is a video i just retook with start up (held the key a little long... not used to holding a camera) you can hear it idle a little better and then hear when i kick it into gear, and see what and when i tap it and then vroom...
i dont know if there is any tightening it so i dont have to tap it or if the new cable will work... it is rigged and may not be working 100%
I am thinking once i get the selector so i dont have to bump it and get the idle set it should be good to go.
jason
