I have a 2003 Caravelle Intercepter 212SS with a MercCruiser 5.0MPI alpha 1 Gen 2 - 260HP. the dry weight is around 2900lbs. The Interceptor is more of a Sportboat hull than a typical bowrider. I typically turn 5200 RPM and even occasionally hit the rev limiter at (audible alert) around 5300 to 5400 RPM. I an running the original MercCruiser 14 1/4x 21P aluminum prop and running with 4 adult men, moderate gear and a full tank. Speed is roughly 51MPH based on the boat speedo, not GPS. The hole shot is OK but not great. I put these numbers into the Merccruiser prop selector and it recommended several Stainless 14 (roughly as all are around 14)x23 options The "details" button on their calcualtor says ideal pitch is just over 22 and top speed should be over 60. Based on this I have ordered a Laser II 13 7/8 x 23 which was the first recommendation. Their calculator doesn't accont for the aluminum to SS conversion anywhere I can see. Did I make a mistake??
