Bought a new prop and it it the trim nano
jrturbowon
Bought a new prop it fit the splines but hits the trim nano. I have a alum. prop 14.25x17 mich. that works just fine but I thought I would try a SS prop so went and got a Rature 14.25r17 and it is hit the nano what is going on.
ziggy
Re: Bought a new prop and it it the trim nano
some props can do that. mine did when i switched props. the cure can be to grind the trim tab to clear..
or if ya got power steering, ya don't need the trim tab anode and car replace it with one w/o a fin on it..
Rocky_Road
Like Ziggy says...or get the Quicksilver offset trim tab:
achris
More fish than mountain goat
I think you mean anode, not nano....
Just file a bit out of it, like ziggy's done in his photo.... Just don't grind it on a bench grinder.. The zinc/ali alloy clogs up the wheel and the next time you try to grind steel the wheel gets hot and they can explode!! :eek:...
