bought boat, cracked block, legal recourse?
ricohman
Re: bought boat, cracked block, legal recourse?
"freeze" plugs are actually 'core plugs' . . .they are not to prevent freeze damage . . . they are put there to clear the casting remains out after the fabrication process.
Why do people call these freeze plugs?
the man
maybe because that is the urban myth, and they do pop out sometimes when it freezes. I have seen that. but i did not know that they were not for that purpose. i have heard them called that for 40 years or so. learn something every day!
the man
H20Rat
I've heard that also, but then why are they plugs? Would only take a couple seconds with a welder to make sure they never come out again, but despite that, they use very tight friction fit plugs..
From personal experience I"ve seen freeze plugs pop from freezing. They aren't a 100% sure bet though, it might only save you from a very light frost.
MarkSee
Good call! I see they have what I think is the same motor on ebay for $2199; $1799 on your link. $400 difference. I owe you a beer.
3 0L Mercruiser Base Marine Engine 140 HP 2013 New in Stock Now | eBay
Look closely and you'll see the less expensive unit is a "reman" for $1799 and the $2199 is "new". I personally would buy the "new" unit and in addition to that, it says the new unit ships immediately where the reman is 2-3 weeks.
There might be other differences also but those were the 2 that stood out.
Mark
ajax5240
Because they do frequently pop out when the engine freezes. Although it is not their original design, they occasionally prevent a block crack.
The fact that they were not designed to be freeze protection, is not known by many.
the man
Mark
Dang you guys are good. "Marksee" sees all.
ricohman
Where I live it can get to -45. So a frozen engine, no matter the vehicle, is completely fractured. I've only seen a couple of these plugs pushed loose, but many, many cracked blocks.
