redneck joe
- Joined
- Mar 18, 2009
- 16,056
Assuming you loaded from phone, did you post from there as well of like this old guy then use laptop?
Everything I post is done straight from my phone. I don't use a laptop.Assuming you loaded from phone, did you post from there as well of like this old guy then use laptop?
You kids and yer phones....Everything I post is done straight from my phone. I don't use a laptop.
Yes it is a lot simpler than I thought! I will continue using it until this issue gets resolved or until we cause Imgur to crash because of all of our boating photo uploadsAppears that platform is the GoTo solution for pics. Pretty simple.
Gotta get with the times old timerYou kids and yer phones....
Pictures are back and working at iboats! So, at least for now, you don't have to go to a 3rd party host.Yes it is a lot simpler than I thought! I will continue using it until this issue gets resolved or until we cause Imgur to crash because of all of our boating photo uploads![]()
Hell yeah!!!!! Thanks for the update!Pictures are back and working at iboats! So, at least for now, you don't have to go to a 3rd party host.
Hi! 2 days on the forum I see! Welcome! Nice to meet a new fellow boating enthusiast! But I have to ask....What is to much energy? Are you responding to an earlier post?Hey! Same here. Too much energy. Bought an old 22' starcraft aluminum. Taking everything out and hopefully not going crazy.
I'm not sure.... whatever three outside temp is at...... it's inside a portable garage.... and I had left the resin out there instead of in my basement. I'm hoping as it gets cooler... it'll work slower and fine me more time before kicking off.What are your ambient temperatures? I noticed my resin kicks a lot faster at 80Fthan 75F. At 85F I get 15 minutes of work time at 1% MEKP and 90F+ is very difficult...
I might do that with the bulkheads. Thanks! What do you say on my other question? Should pb into bare stringer wood and glass over or glass over the stringers first and then pb in to give it that barrier just in case?If you want to glass up your wood components 1st on a work table then set in pb with spacer and all that's left is tabbing. Much easier to do flat work.
You can also use less mekI'm not sure.... whatever three outside temp is at...... it's inside a portable garage.... and I had left the resin out there instead of in my basement. I'm hoping as it gets cooler... it'll work slower and fine me more time before kicking off.
No the glass should overlap all corners and joints.I might do that with the bulkheads. Thanks! What do you say on my other question? Should pb into bare stringer wood and glass over or glass over the stringers first and then pb in to give it that barrier just in case?
