JordyOutboard
Thread starter- Joined
- Aug 16, 2015
- 50
Disclaimer: I have never owned a boat before and really don?t know the first thing about them. I do consider myself to be someone mechanically inclined as I do all the work on my vehicles myself. I also have about 14 vintage motorcycles that I perform all the work on as well. If there is a idiots guide to boats that I can read, please point me in the direction. I would like to know the do?s and don?ts of operating a motorboat.
I bought a 1996 Maxum 1700 sr with a 1996 Force 120 outboard two stroke engine. The previous owner was the second owner and seemed to be a very genuine guy. He said he hasn?t had any issues with the boat and it?s ready to go. He takes it out probably 12 times a season with no issues.
So I bought the boat and immediately took it to the water when I got home. I launch the boat without any problems and start her up with the trim completely down. I drove it around for about 30 minutes at various speeds. The 17 foot boat with two adults reached about 34-36mph.
Eventually we found ourselves in some shallower water. I would estimate around 3 feet deep based on how we could see the bottom. At this point we were stopped and to go again I decided to pull the trim up so the props were not as deep into the water. As we started to go the boat started to plane higher than usually based on the trim placement. We drove it for around 5-10 more minutes and then the engine started to bog down to an idle and then shut off completely despite the throttle being open. I did not hear any buzzers or alarms so I am not sure if I over heated it. The engine cover did have some smoke coming from it for a few minutes but nothing other than that. After a few minutes I tried to restart the engine to get us back to the launch but it didn?t go. The battery started to drain at this point. I also noticed that the battery connections were EXTREMELY hot. I am not sure if its because the connections were loose or what.
A nice guy towed us back to the launch and I brought the boat back to the garage for the day. The next day I cranked it over and everything was fine except it didn?t start.
Anyone know where I can start to trouble shoot this thing? I ordered some outboard motor flushers so I can safely attempt to run it while out of the water. They should be here by Wednesday I believe.
I pulled the plugs and they were not completely dry but were not soaking wet wither. I cleaned them off and tried to turn the boat over. It felt like it wanted to start and I also heard a small backfire as well.
Should I start by checking for spark? I am not familiar with these kind of spark plugs. How can I test spark? Ill also do a compression test as well.
Thanks for all your help. I hate that this is my first post but I guess that?s boat life?.
