Bow eye hardware question
SgtMaj
So I bought a new bow eye the other day to replace the old one with (post was nearly rusted down to nothing. I had to sheer it off to get the old one off, but it took almost no effort to sheer off the old bolt.
Anyway, when I opened up the packaging on the new bow eye, I was a little disappointed in the design. It's a common bow eye and is even carried on iboats (though I bought it from a local store here). The problem I see with it is this. The hardware (nut, bolt, and washer) on the new bow eye is made of galvanized steel. Although that will last for 20-30 years on the lakes I fish (it wouldn't last nearly that long on salt water), it will eventually rust out however. I would like something that will last for many generations though. So I'm thinking I can just replace that hardware with stainless steel. The bolt does unscrew from the bow eye.
So I'm wondering if anyone else has done this, and where a person could get stainless steel nuts bolts and washers to fit it.
tashasdaddy
Re: Bow eye hardware question
i've use the seadog one with no problems.
If you use what you have,.....
And,..... Bed it properly in sealent,......
It's Outlast You........
Most of the Big Box stores carry a limited amount of SSteel bolts,+ hardware.......
But,.....
You have to consider than most SSteel bolts are Much Weaker than the gal. Steel you've got.......
tashasdaddy
then you have the electrolisis of different metals, also.
