Bow Grab Rails and Murphy
SimpleMan
We'll Murphy has sure messed up my plans for this weekends fixit job. I have a runabout with grabrails on the bow made from stainless tubing and 60 deg standoffs.
The front zinc standoffs have corroded pretty badly and I just wanted to replace the front two after many years in service.
Unfortunately I discovered that the height of the factory standoffs is higher thant those available commonly today. My old ones are 2.5" from the deck to the top of the rail. New ones are ~2". So I resigned myself to replacing all 6 to get the height correct.
I have now discovered that the bolting pattern is slightly different as well. Those available from west marine have 1" bolt centres and my old ones had 7/8" centres.
Does anyone know where I might by the old style? Someone told me they are old Perkos but I haven't found anything.
If I have to redrill, does anyone have any good advice to rerill a hole for a 10-32 a short 1/8" from the original hole?
Also, the ones available from the local chandler do not have set screws. Any advice for keeping things secure without them?
Frank Acampora
Re: Bow Grab Rails and Murphy
I just scrapped out a boat with these fittings. Give me a day or two to find them (Don't ask why) and I will get to you in a private message if they look correct.
NYBo
I would use one of the original holes and drill the second 1/4" out from the other. I would also use a backer of some sort under the gunwale for strength.
SimpleMan
Here is a pic of the grabrail standoff that came off the boat. The boat was built prior to 1988 when my Dad bought it new. The centre to centre distance on the mounting holes is 7/8" and the tube OD is 7/8" too.
DC20
Maybe you could find some place that can refinish the old ones?
SimpleMan
Thanks for the suggestion DC. These fittings are so far gone that the end fitings have turned into center fittings (the tube can slide right through). My photo shows the end I thought I would not have to replace.
