Re: bow rider front seat removal
Roger, this is some 3 months after your post, so you have probably since figured this out, but I may have an answer for you. My 2004 MX175 appears to have the bowrider seats attached in a similar fashion, as they are resting on the molded fiberglass rims. While no screws are visible, mine had 3 rows in the front and 3 screws in the rear, coming up from the underside of the fiberglass and into the plywood bottom of the seat. I had to forecuflly rip the plywood out, which was somewhat doable as it was wet and partially rotten and some of the screws had already come out. You may be able to get to the rear screws that are closest to the consoles from behind, but maybe not. Good luck and let me know what you find out. I'm currently trying to find a way to reattach the seats myself, so let me know if you have any solutions.
