Bow roller question
fishin0001
1996 bass tracker 185, I bought this last year and noticed the bow roller was bad so I replaced it, since it's used is this the way it looks to trailer or does the tether go over the roller?
thanks for any info
Most all go under the roller. Its under, so if the boat bounces the strap keeps the bow on the trailer
JimS123
The "tether" should run between the boat's bow eye and the trailer tongue. The winch's cable (or rope or strap, as the case may be) should go under the roller, just as pictured.
H20Rat
Under as mentioned, but you also want to get yourself a safety chain on there. Never trust a winch.
SkaterRace
What my boat (brand new 2018) came with was a simple ratchet strap that hooks onto the frame instead of having a chain that hooks onto the winch tower.
Just something to consider. But yes the winch and safety strap go below your roller
JimS123
Yup, the strap makes more sense, It holds the boat down tight on the trailer. The saftey chain catches the boat as it goes flying off....LOL.
But what's all this about chains anyway? My old boats all had chains with hooks that could easily bounce off. Today, the better trailers have steel cables with hooks, both the boat safety cable as well as the trailer / hitch cables.
Yup, something to consider...
(PS - whats a Galstron?)
SkaterRace
Ops typo on the brand name lol glastron :facepalm:
The strap I think is better than a cable to me because it helps hold the boat down along with doing everything a cable does
dingbat
Not a fan of straps......I've had two break on me over the years. Ended up going with a turnbuckle and chain.
SkaterRace
I like that idea, how much of a pain is it to use? I would think to get it tight enough you would need to put some elbow grease into it
GA_Boater
Easy to use. I just hand tighten the turnbuckle as tight as I can get it.
It works, too. Had the winch lock spring fail once. And I use transom straps as well.
dingbat
None at all.
Pull the boat to the bow stop with the winch. Install turnbuckle and tighten by hand, then a 1/2 turn with a 6" adjustable wrench. Back winch cable off to relief tension on cable.
Can't use transom tie-downs because of trim tabs. Use a 3" ratchet strap (#18k) over the gunnel to secure the boat to the trailer.
