Bow safety chain or strap?
90stingray
When should a safety chain be used and when should a strap be used? Both are in conjuction with the winch strap of course. My trailer came with a loop welded to the winch stand... i am assuming for a strap. But i drilled a hole in below the winch and mounted a wratcheting nylon webbed cargo strap. Didnt want to pay the $40 for the boatbuckle brand tiedown. Just wanted to see what everyone is running for a safety. I have a 17'-6" boat is on single axle trailer. Thanks.
cribber
Re: Bow safety chain or strap?
I personally use both my bow strap that's attached to the winch and a safety chain that is bolted to the winchstand. I always make sure both are connected to the bow eye every time we trailer our boat the 5 mile drive to the ramp.
jeffnick
I hook up the safety chain, then take the slack out and secure it with an old transom ratchet.
HappierWet
Master Chief Petty Officer
I use chain wrapped around the trailer tongue below and slightly behind the bow eye. The transom straps will keep the boat from moving back if the winch straps break. The chain is setup to keep the boat on the trailer in case of emergency breking and the winch mast fails.
tpassmore
if the trailer comes loose, you don't want the boat flying off the trailer. i lke Jeff's setup...removes all bounce and relieves stress on strap and boweye.
JB
On my boat i use a turnbuckle.
Exactly what I use. Welcome to iboats, cajun man.
I don't trust the winch strap or the winch stand to hold the boat in the event of a collision or emergency braking. I turnbuckle the bow to the trailer frame. If the distance is too much for the turnbuckle alone, add some chain to it.
Silverbullet555
I use the winch strap, a strap to hold the bow down and remove bounce and finally a chain from the bow eye to the trailer as a safety mechanism if everything else fails.
the vision
I use the winch strap saftey chain hooked to the winch stand, and transom binders.
Expidia
I used to use those web straps, but they tend to dry out over the years and I'm sure the sun weakens them if they are nylon.
I now only use chains. I'm sure the turnbuckles work too.
This pic shows the benefit of using safety chains etc. :eek:
gozierdt
and some people wonder why a lot of us don't like Bayliners...
speedgater
I have used both, and both are just a safety back up, but I like the webbing better because I can sinch it down to take out slack were a chain you can not. Just make sure the webbing or chain has the propper rating to hold your boat to the trailer.
smokeonthewater
they actually as alluded to above serve different purposes.... the strap is there to cinch the bow down and the safety chain it there as a backup plan should the winch fail to secure the boat
mphy98
I use all three. The winch strap, a bow strap, and a chain. Plus 2 rear tie downs as well. I take long trips to Canada and I do not want ANY problems. You can never be too safe, even if it is a short trip. Sometimes those can be the most dangerous. It only takes a minute or two to undo the straps and chains.
89mercruiser
We have two transom straps and the winch strap with a safety chain. When I load the boat the first thing I do after winching it snug i hook the safety chain.
LippCJ7
Winch strap, safety chain and two transom straps here
I'm surprised nobody picked up on that dodge being overloaded........
