br7es vs. br8es?
jimmytee
Just noticed the manual calls for BR7ES plugs, both Seadoo XP have BR8ES in them...any significant difference between the two? Whats the correct gap?
Torino117
Re: br7es vs. br8es?
Friend has an older yamaha that calls for BR8HS, but he runs BR7HS, he says it burns more of the oil off, less fouling I presume, so it runs better longer. I'm not sure of the difference on the ES though.
ridefst
It's just one heat range different, lower numbers = hotter plug (at least for NGK's like these, I think other mfg's may be different)
Not a big difference, a hotter plug may keep it from fouling out a little better, if you were having a problem with that.
Torino117
Hey Vikes, uhm the BR7 actually runs smoother. Also, I just added the reference to those plugs to help out Jimmytee, I'm not the one that needs the question answered it's Jimmy with the sea-doo. But the gap sounds good for everyone :cool:.
Vikesfan
My bad. :cool: If its a Seadoo XP then the right plugs would be a BR8ES for the 951, 720, and 650 engines with a gap of .022 and BR7ES for the 580 engines with a gap of .022. The 2003-2005 951 DI engines need a ZFR4F-11 NGK Plug with a gap of .035.
