sludgeguy68
Thread starter- Joined
- Jul 16, 2010
- 111
Still trying to figure out the cause (I'm still new to boating). This is the first season I was able to take out my boat - 1978 inline 1400 on a CMC jack plate - the thumbscrews for the transom clamp don't match up with the jack plate nicely (they wind up resting on the tops of CMC bolts), so the PO placed blocks of wood in there, I guess for a better grip. Now I kick myself for not looking into that weirdness over the winter.
I suppose I hit something on the water (no one really felt a jolt or anything), the boat just felt weird. I checked gear shifting and went slow, everything seemed normal. I think this is when the wood blocks may have gotten knocked out. I eventually opened it up to go back home and it was pretty choppy out, hit a bunch of waves, no problems all sounded/felt fine. Then the motor suddenly tilts 45 degrees sideways at WOT and almost dumps us in the water. I'm really glad the boat didn't go under and the motor hung on.
The trim brackets snapped at the jack plate, and the transom clamps broke at the thin bottom piece where it also bolts into the jack plate. Also have a chunk of metal missing from the the LU fin (where it separates when you drop it to change impeller), and the lower cowl disappeared.
I suppose once the wood blocks were gone, there was this 2" gap behind the clamps, and that didn't properly support the motor from stress.
Looking for any advice on repairing this and inspecting for other broken parts (tilt tube?) The trim brackets don't look too difficult to replace but it seems like the powerhead will need to be pulled to replace the clamp brackets. Also going to try to inspect for damage to the transom once I can get it out of the water.
Thanks in advance
Thanks in advance
