Nextelbuddy
- Joined
- May 4, 2020
- 163
So I just replaced all the spark plugs in my mercruiser 5.7 I use the recommended Quicksilver AC MR43T spark plugs....
I I was running wide open throttle 4800 RPMs for probably 3 minutes The boat had been running great all day and then all of a sudden I heard a loud gunshot and then a really bad noise probably the compression stroke of that one cylinder because the spark plug was missing.
II thought maybe I was just dumb and I didn't thread in the spark plug tight enough and it loosened up and popped out but I looked up into the cylinder head and I found the broken part of the spark plug and the electrode porcelain part exploded off leaving the threaded part of the spark plug still in the cylinder head so it almost looks like the spark plug just was a manufacturing defect possibly?
now I'm nervous to run these spark plugs now and want to change them out to something else.
would engine detonation cause the spark plug to blow out like that leaving the threaded part still into the cylinder head?
Is is there another recommended spark plug that I can run for my engine?
