Bravo 1 slipping prop condition...
Cdn20valve
Donzi lxc 255. 5.7 Efi Bravo 1
On the weekend, took my boat out. Cruising was ok, till about 2500 rpm. Had a hard time getting on plane. Actually it wouldn't at all. Revs would climb up to 5000rpm, as if a clutch was slipping on a car. Prop would barely spin. I though spun prop Hub...
So I brought it back to the marina, swapped props to a known good one, and went back out. Same thing!
So I cruised the river for 30 min till I got to the lake. once there,mI played with the trim and finally got on plane. Power was back, all was good. Everything was great till the end of the day. On my way home, I started 'cavitating' again. This time there were some odd noises as well. Not growling. But like something was loose. i lowered the throttle, noise went away. Raised throttle again, no noise... I limped back to the ramp, took the boat out of the water. And headed home.
Today, I took the drive off to inspect.
Btw, This is a rebuilt drive and engine. Place I bought it from installed it before I bought the boat.
Gear oil is perfect!
Prop is perfect and brand new.
No play in driveline. All looks ok. U joints etc all greased and new.
Next is to remove gimbal housing and inspect gimble and coupler.
One thing I didn't check is the gear cable adjustment.
I did find a loose triangular shim in the drive case where the UJ are..not sure where it came from....
What do u guys think?
tpenfield
You might be trimming up too much and the prop ventilates as the boat tries to get on plane.
Cdn20valve
If the coupler was bad, it's not something that would fix itself, than go bad again, correct?
Correct, it won't go bad an come back. Sounds to me like the trim is to high. You could check to see if the prop is spun but this to does not go bad then return
Ayuh,.... Welcome Aboard,...... Is it Weedy in yer marina,..??
Did ya shift to reverse, bump the throttle, 'n then shift back to forward, before ya tried to get on plane,..??
Have ya checked the contents of, 'n changed the fuel filter lately,..??
My guesses are,.....
Yer prop was fulla weeds, so ya couldn't plane off,....
The noise you were hearin' was Detonation, from workin' the motor real hard, 'n it's probably runnin' abit lean, so Detonation kicked in, 'n ya heard the bbs in a tincan rattlin',....
If I'm right 'bout the Detonation, get it fixed, Quickly, as that noise is yer motor consumin' itself, bit by bit,......
Cdn20valve
Very weedy in the marina! I noticed weeds around my prop when I pulled out of the launch. Had to pick them out.
Cdn20valve
The noise might have been the exhaust flapper breaking off? I'm familiar with detonation. The noise wasn't as high pitched.
Cdn20valve
No Title
Busy day. Ended up taking the motor out. Not that bad of a job really. There is some evidence that the coupler is compromised. What do u guys think?
Scott06
I would think that's slipping. Was there smoke or burn smell when this happened?
Cdn20valve
sone burnt rubber smell. But it did not last long. Can I upgrade the coupler? Or do I have to use the alpha triangle style one?
Cdn20valve
No Title
On reassembly... Look what I noticed! Crack in the bell housing.
Ayuh,..... The Flywheel Cover,..... Cracked at the rear motor mount,.....
