bravo 2 service
scoflaw
Ensign
Not much talk on this. Do you wait until water is in your outdrive, or do you split halves and do a reseal every so often? I,ve got oil gettin out, no water in yet.
Don S
Re: bravo 2 service
Fix the leak, replacing all the seals is way to expensive. Have you pulled the drive and checked the bellows for gear lube?
Re: bravo 2 service
Ayuh,... I have mine resealed/ rebuilt as soon as an Issue is discovered...
scoflaw
Ensign
Re: bravo 2 service
No oil in bellows, oil loss is getting worse as the years go by. Pressure checked OK. Dubs suggested prop shaft seals. Wasn,t sure what the dilly was between the upper and lower.
