- Joined
- Jul 18, 2011
- 19,646
You can never have too many anodes on a Bravo 3 outdrive, it seems, particularly when using/keeping the boat in salt water.
I have been getting a bit of corrosion each season on the Starboard side outdrive gimbal ring. I probably need to do a rebuilding on the transom assembly and make sure all is good with the mercathode and continuity wires, but that is still a few years away for that exercise. So, I decided to add a couple of anodes to the gimbal ring to give it a better source of weak metal and associated electrons
I figured that right below the trim sender/limit switches would be a good place to put a clamshell anode. Here are a few pictures of the installation.
Drill & tap a 10-24 hole
Here are both drives . . .
We shall see if these make a noticeable difference at the end of the season.
