Hi,I thought I would post some new information just so that you are aware of that if you do end up needing a new prop shaft seal in your bravo 3 sterndrive, Then just make sure of that what ever Mercruiser service shop that does the work for you is aware of that there is a new style seal to help stop this leak from happening again. The Mercruiser shop that does this repair for you will want to have a look at Service Bulletin Number 2010-64.
The new inner propeller shaft seal part number is
26‑8M0033407And the old seal part number was 26‑861695.
They also have a new Seal removal tool ? Part number 8M2013914.
Here is some general information about it.
A new inner propeller shaft seal with improved sealing characteristics has been developed. A new seal removal tool is also available
which makes it easier to remove the inner propeller shaft seal without damaging the needle bearings behind the seal. Refer to
CMD Service Bulletin 2009-14.
For inner propeller shaft seal removal and installation instructions, refer to Service Manual #39 Bravo Sterndrive.
a - Original‑design Bravo Three inner propeller
shaft oil seal with helix pattern on seal face.
b - New‑design Bravo Three inner propeller
shaft oil seal without helix pattern on seal face.
