bravo 3 prop end play???
Tailguner
On my bravo 3 i can feel a slight play vertically when i pull on the first larger prop pulling up toward the smaller second prop is this normal?? I tightened the nut really good but still has some play in it .
TilliamWe
Banned
Re: bravo 3 prop end play???
I think that's normal. The "washers" that are used on a B3 shouldn't allow you to install them improperly. And if you did put one on the wrong side of one of the props, the other prop wouldn't fit. Are you sure you have the "washers" in the right place? Got a picture?
