Good question, but no . . .
There should be a plastic ring in the outer part of the nut, which is like a 'nylock' nut. That should be facing away from the lower unit. The beveled side goes toward the propeller it is securing (i.e. the lower unit), so that it along with the beveled collar sleeve are centering the prop on the shaft - front & back.
Like this . . .
