Bravo 3 Speedometer
captain zac
2001 6.2 B-3
Speedometer just quick working
not sure where to look first
indicator is pegged at 0
no work has been done to the outdrive or the engine since it worked last
all other gauges are working fine
can't fine it in the manual must be looking in the wrong place
Harry
Don S
Re: Bravo 3 Speedometer
Two places to check. The pickup hole in the leading edge of the drive can get plugged with debris in the water.
Another thing that can happen is the hose come off or get connected or the plastic connector breaks.
Silvertip
Honorary Supreme Mariner
Not likely a ruptured hose as there would be water in the boat. There are no electrical connections on a speedometer except for the internal light. Water pressure acting on captive air in the system is what makes the dial move. Follow the hose from the back of the speedo to the engine.
captain zac
I will be able to check both of your ideas wed. or thur. this week
I will right my results after that
Thanks
Harry
MarkSee
When I was investigating the same issue and went to check the pickup hole for dirt, I could not tell using a wire if I was hitting packed dirt or the case so I found using a very small drill bit and turning slowly by hand both directions freed up the dirt that was there.
Mark
captain zac
Guys
I will be pulling the boat home on Friday
Trying to get this fixed this weekend
If I find that the intake hole is clogged then remove and I am good to go
but
If the tubing has fallen off what do I need to do before I reattach it
(do I need to blow out the line or what )
Harry
TilliamWe
Banned
If the tube has fallen off, you need to see if the fitting is still attached and not broken. If it's intact, you need to re-install it, in accordance with Don's photo above, and it'll work. No need to blow out any lines.
captain zac
OK
Cleaned out the intake
I should be able to put it in the water this weekend
Harry
