Re: Bravo 3 transom seal R&R
Like Don was saying.....Find the leak before you take everything apart looking for it.
It's pretty unlikely that the transom seal is leaking or has started leaking.
If it was leaking it probably would have been leaking from "day-one".
Unless a transom seal is put on wrong (I.E. with a large gap in the seal ends and/or maybe not cementing the ends where they meet etc) They almost never leak.
When I installed mine it came with a diameter that had it fitting in the transom indentation perfectly. It kept falling out so I used a little trim cement to hold it in place while I was putting the gimbal on the transom.
More than likely you have a leak in the main (drive shaft) bellows or shift cable bellows. one or the other may have a small crack in them.
I also had a (what I thought was a) leak too. It turned out to be the speedometer tube.
It was disconnected. and when I was just sitting in the water not moving, water was pouring in thru the point where the speedo tube pushes onto the fitting. (my drive speedo pitot is plugged down below so I have to use a plastic stern mounted speedo-pitot.)
I had that thing out yesterday at Lake Tapps, Wa and at 4600 RPM, 26p props 1.8:1 drive I was running 58 mph!
My brother was with me (first time he's seen the boat since I bought it from him)
He told me that it runs better and comes out of the hole better than when he took delivery (new) in Las Vegas in 1987!
Now he wants the boat back!!!
I think I'll keep it!!
Cheers,
Rick
He was referring to the transom seal. It's that 3/4" dia rubber ring that goes aroung the transom shield to seal the transom shield onto the transom. Very similar to the Volvo seal.
To replace it, you have to pull the engine so you can pull the transom shield out of the boat to put the new seal in.
FInd the leak before you start fixing things.
