gapple12
- Joined
- Sep 15, 2013
- 174
So as I’m working on my boat this past weekend, I noticed a small puddle under the outdrive. Further investigation I found it’s leaking from starboard trim cylinder where the shaft enters the cylinder (pic attached). I would say it dripped about a tablespoon all day on the ground. I’ve researched a little and everyone says it’s a easy job doing the break down and replacing the seals. True or should I just replace the whole cylinder? I’m seeing them up around $300 a side but the rebuild kit is around $20.
im not sure I’m finding the right parts, are all mercury bravo 3 drives the same?
