Bravo 3 trim issue
Tunabass
The blue wire coming out of the plug by the pump is not connected to anything about 12” back from the plug. Looks corroded but I can’t find where it should be connected to.
alldodge
I just checked red to blue white with no button push and it reads 17. Same as with the red to green with no button push. Battery was off.
That makes no since, your reading 17 ohms from red to either which should be an open circuit
Look at drawing in post 5
The Blue/white goes from the 3 pin connector to the top relay, and is the reason there is no up
Tunabass
The blue wire I’m talking about is the solid blue skinny wire that comes into the plug not the thicker blue/white wire that goes from pump to solenoid.
alldodge
Can you post a pic?
I don't know of a solid Blue wire unless its an older model then it would go from the pump to relay, but would not go the the plug
Tunabass
Figured it out. The blue wire going to the plug that was broken 12” away connects to an unlabeled purple wire. Thank you for all your help.
