Re: Bravo 3 XR changing ratio from 1.81 to 1.65
they dont twist them to 30".
28" is maximum when running a 3 unit.
There is some mhp gains on changing to 3xr 4+3 setup.
30p 3-blade Bravo III props actually ARE available. I have seen more than one set on EBAY for sale
There's also a company now that manufacturers 4x4 props for the Bravo III drives.
Did your engine/drive combination come new with a 1.81:1 Bravo III?or did someone cobble that engine and drive together and install it in that particular boat?
Mercury designs their drives and propellers to operate at specific maximum RPM ranges for maximum efficiency.
For example, A 300HP 5.7L (gas) V-8 has a recommended RPM range of approx 4400-5000 RPM. Using a (2.0-2.2:1 ratio) Bravo III drive and suitable prop-set, you get propeller RPM ranges of 2200-2500 and 2000-2272 RPM respectively.
It appears that Mercury may have intended the Bravo III propset to have an upper limit of around 2500
A single prop (Bravo I ) with a 1.5:1 ratio (@5000 eng RPM) would produce a "max" prop RPM of about 3300 RPM .................stock Bravo III installations aren't usually setup to produce prop RPM's that high.
Since your particular engine has a governed maximum speed of 3800, in order to achieve approx the same max propeller RPM, you would need a ratio *around* 1.7-1.9:1 With 1.65 being optimum to give you approx 2300 prop-RPM
If you used a 1.36 ratio, you could conceivably achieve a maximum propeller RPM of approx 2800. That might be too high producing either excessive vibration or cavitation at the higher speeds.
Your best bet might be going with a 1.65:1 drive as you indicated.
A 1.65-to-1 drive, 30p props and 3800 (using the prop-slip calc below) would yield approx 60 MPH with 10% slip.
Prop Slip Calculator
That engine would certainly achieve "Hole-Shot" RPM's with ease due to the high available (low RPM) torque.
Using the 4x3 or new 4x4 props, you may be able to limit the upper RPM to just below governed maximum engine speed but it will require experimentation. Most propshops will allow you try different propsets as long as you buy one of them.
Please post your test results! Be sure to use either GPS or a calibrated speedometer and an accurate tachometer.
Cheers,
Rick
