S helping a friend replacing gimbal bearing, bellows, shift cable, etc. Its a bravo 3x on a 25' Parker w a yanmar 260 turbo diesel. The plastic fitting for the gear oil tube was so porous that when touched it crumbled. So now a simple maintenance jib turned into a big headache.is this a common problem? How can this get fixed? Does this fitting just pull right out? There has to be some attachment on the inside of the boat, which I cannot see? Does the motor have to be pulled? Any info would be helpful?
