Bravo I outdrive issues
Donnie Durbin
I was running on plane when it sounded like I spun a Prop. I pulled it back in neutral and then back in forward. I could here a lot of grinding noise and the faster I went the louder it got. Right before the incident I noticed a high pitched sound from the outdrive. I trolled back to the dock, but the grinding noise never went away. The out drive will only go into forward. Coupler or Gimble, or both?
Bt Doctur
Re: Bravo I outdrive issues
more likely a blown upper unit.Pull the drive and inspect.
