Bravo II drive
GasCan II
Hello guys, I have a chance to buy a Bravo I drive at a very nice price. The question is will it swap out for a Bravo II drive ? And if the gear ratio is the same , will it perform the same .
Thanks
Ayuh,.... It'll bolt on just fine,...
The gear ratio may, or may not be the same,....
'n Nope, won't handle the same at all,....
The BII is a HUGE boat drive, kinda like a Tugboat, a HUGE prop,....
The BI is a standard size drive, usin' standard run of the mill props,....
the B1 and B3 are similar sized, where the B3 has the dual props
as Bondo pointed out the B2 is HUGE. the B2 takes 20" props and was designed for big loads like houseboats and tug boats and fishing trawlers
