bravo II rebuild
netting one
Im looking to change the coupler,u joints,bellows,gimbal bearing all of it in my 98 proline. its all factory stuff. i also want to go through the out drive and replace the bottom half, its all pitted and has a big chunk out of it. were do i start to get all these parts? thanks dan
dubs283
Re: bravo II rebuild
most you will be able to find here on iboats
the ones you can't find are available at your local mercruiser dealer
btw - you are gonna need an OEM manual and some special tools to rebuild the lower half of your drive and they aren't cheap
Ayuh,.... Everything mentioned in your 1st sentence is available here at iboats,...
Or Mercruiser,... Your Dealer, or on-line...
The lower unit will have to come from Mercruiser, or Used....
Mischief Managed
A Bravo 3 gearcase with the same pitch props you have on your B2 would be a really nice upgrade, and adirect bolt-on.
However, it's not really an option without changing the gearing in the driveshaft housing if you are running less than a 20" pitch prop on your B2 though; I'm pretty sure they don't make Bravo 3 props smaller than 20" pitch.
