BRAVO lll OIL CHANGE
HT32BSX115
Re: BRAVO lll OIL CHANGE
I copied right from the Merc serv manual above in post #11 and anyone who has changed their own gear lube on a unit that has a bottle will attest that lube will continue to flow upward and fill into the bottle past the vent hole.
yes it will indeed!!
Cheers,
Rick
BIGALF
OK Thanks for your help.This time I will just fill in the balance from the resovior with the drive in the down position when I put it in the water this weekend. I'll run it awhile then recheck. Next time I will do it with drive down vent closed and cap off.
