Bifflefan
Thread starter- Joined
- May 27, 2009
- 2,933
I have looked a bit and don't find an answer or even a similar question.
Can I install a fitting into the water pickup hose between the pump and the leg so run on the engine on a hose instead of using muffs on the leg. The reason is the muffs I have either dont fit well or the set that does has too small of hole for enough water to flow and they get sucked flat when I run the engine.
Or is there another way I am not thinking of?
