G GasCan II Petty Officer 1st Class Joined Jul 15, 2010 Messages 281 Jun 3, 2015 #1 Are these two drives interchangeable? Any advantages of one over the other ? Thanks
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,417 Jun 3, 2015 #2 Ayuh,.... All the Bravo upper units are the same, only the lower units change,.... The B-II is a tug boat drive, it swings a Monster prop, like for houseboats, 'n barges,..... Goin' from a B-I to a B-III is usually a Good move on most hulls,....
Fun Times Moderator Staff member Joined May 16, 2009 Messages 9,310 Jun 3, 2015 #3 Yes they are interchangeable fit wise. But depending on the years of the drives you have to be careful of the oil passage hole between the upper and lower units as the earlier years didn't have an oil passage like the later models did. BRAVO DRIVE UNIT/HOUSING COMPARISON AND IDENTIFICATION DRIVE UNIT GEAR RATIO IDENTIFICATION Also you have to know the gear ratios between the two drives because the lower has different gear tooth counts. http://www.mercruiserparts.com/Show_...%28BRAVO+II%29 -1641-8294A19GEAR HOUSING ASSEMBLY (1.50:1 - 1.65:1 Ratio) $4,350.00$3,896.081 -1641-8294A16GEAR HOUSING ASSEMBLY (1.81:1 - 2.00:1 - 2.20:1 Ratio) $4,350.00$3,896.081
