Bravo One Vs. Alpha?
eb0248
Re: Bravo One Vs. Alpha?
Tell your wife that there are more than a few people that will gladly take the Nova off your hands, should you want to rebuild the '86 lol
Hows that coming along?
Ayuh,... Can't seems to get it to the Top of the list,.. Never any Time...
Did spend a few minutes laying out an X dimension the other day,.. Don't know how much to raise it....;)
You packrat :)
No $h!t,.... Olympic Class Dumpster Diver,.... :D
What do ya Need,.. I've probably got an old Used 1......:p
wca_tim
I stand corrected on drive weights. Maybe I was thinking of a bravo 3. When I was making decisions on drives, I worked through a number of options for power and drives and am sure that by the time all was said and done I would have been adding close to a couple hundred pounds if we had changed out to a different drive from the gen 1 alpha that I'm running now.
and yes on > 400 horse in a 17 (and 1/2) foot boat. have been into the mid 70's with the 28" and 29" props and 1.81:1 gear ratio. So far a Hydromotive quad 4 was the best on the top end. At the end of last season we were running high 60's / low 70's with a 27" Mirage plus and the smart tabs too far down (set up to stay on plane at low speeds pulling daughter and her friends wakeboarding...). I generally don't rev it past 5500 rpm... Not sure how accurate the tach is and am going to see about another while I have it apart over the next couple of weeks.
Great looking Nova in the pics above...
Have been running Mobile 1 synthetic 75-90 wt gear lube in the outdrive
Rotella T 15-40 in the crankcase with a merc bigblock external oil cooler and filters... 7 quart oil pan run a tad low by the original dip stick.
Bond-O, what are you thinking on raising the x-dimension? (how far?)
Ayuh,... An Inch anyways,.... That's the Big Question...
Moving the motor forward a ft., ft.+ 1/2, running a jackshaft,..
Fuel load will be at, or slightly forward of original,...
I'm thinking 2" is Too many,... 1,+ 1/2" maybe,..??
'course then there's the swapping to a B3 lower Option.?.?.?
HT32BSX115
:eek::eek:
CAREFUL!!
Even mention oil around here and it transforms into an "OIL THREAD"
And then where will we be? :rolleyes:
