Guy?s can you tell how hard it would be to change my Bravo out drive with a Alpha 1 drive?
R Richard74 Cadet Joined Sep 10, 2008 Messages 12 Apr 3, 2009 #1 Guy?s can you tell how hard it would be to change my Bravo out drive with a Alpha 1 drive?
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 Apr 3, 2009 #2 Re: Bravo out drive You would have to replace everything from the flywheel on back, transom shield, inner transom plate, Y pipe, all of it.
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,467 Apr 3, 2009 #3 Re: Bravo out drive Ayuh,... You've got Mercruiser's Best,... Why would you want to replace with an Alpha,..??
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 Apr 3, 2009 #4 Re: Bravo out drive Bond-o said: Ayuh,... You've got Mercruiser's Best,... Why would you want to replace with an Alpha,..?? Click to expand... Probably found out the cost to repair or replace a Bravo.
Zackman Petty Officer 1st Class Joined Dec 3, 2005 Messages 376 Apr 3, 2009 #5 Re: Bravo out drive I think the real question is what engine do you have? 300 Hp is usually the cutoff point for an alpha... Hence the bravo drive was developed.
