Thajeffski
- Joined
- Jun 2, 2009
- 890
Re: Break Out Another Thousand.
100 bucks? yea right buddy, that's more than a thousand or two.
This is why a chart of the area is invaluable.
Yes, check for milkiness. You shouldnt have to drain any. Your outdrive should have a short dipstick or fill hole in the top that you can stick a screwdriver into (if necessary)After I put the new prop on, what should I look for as far as ourdrive damage goes? I can drain a little gear oil from the drive and check for milkiness as mentioned... but what does that mean? Broken seal I assume?
Well, my plan is to pull the prop and take it to a shop to have it refurbished and a new hub put in. Then I'll reinstall and see how it runs (after fiberglass repair... anyone know a good DIY repair kit?)
One more thing, upon closer inspection, the exhaust bellows popped off the drive (still attached to the transom). I know it doesn't hurt anything to run it like that, but I'm curious how that could have happened. Possibly when I was dragging the drive through the mud?
Wow.
I think you are way underestimating the potential damage and the costs to get it fixed. If your bellows came off you may have some serious damage to the bellhousing/gimbal ring. About the only way the bellows would come off is if the drive itself was pull rearward during the incident. Considering the skeg and prop damage I think it is completely possible that you did more damage that isn't as obvious.
The hull/keel damage is also more serious than you seem to want to admit. You have completely gone through the gelcoat. The glass has obviously sustained damage. You can fix it right or fix it again. Any "repair" kit you try may give you some more time until the damage starts to either cause other problems or degrades to a point that it no longer protects the structure of the boat. With that kind of damage there is a real issue with water intrusion into the layers of glass and the potential damage that can be caused (freeze). Delamination is also a concern.
I had a little incident at a boat ramp a few weeks back and had a much smaller "scrape" on the keel of my boat. It was probably as deep as yours just much shorter in length. I had it proffessionally repaired for peace of mind.
Do you have insurance on your boat? I made a claim for my incident. If it was worth it for me to make a claim, I'm sure it would be worth it for you. With the skeg, prop and hull damage, you are at 2xBOAT easily. If there is more damage in the outdrive that you can't see 3xBOAT.
"A bellow popped off too???" Not normal at all! That needs to be fixed too or you risk sinking the boat next time you go out. Dude......... you have an insurance claim. You will poop your pants once you find out how much it is to fix the ss prop. If you are going to run your boat in rocks at a minimum get an aluminum prop! The hull, outdrive and engine need to be looked at by a proffesional. Usually when you hit with a SS prop the outdrive goes to.
Good luck!
get liability insurance before you go back out. Your incident explains why.
a depth finder tells you what you are hitting, not what you might hit. Especially in rocky areas--I am generally around slopes, and soft bottoms, which is entirely different. you can have your bow on a rock with the transponder over 10' of water.
ambiguous bouys and similar markers indicate either channels, or hazards, and no telling which is which. Do not rely on them unless you know.
On the exhaust bellows, there is a new bellows out now that only attaches to the transom side of the drive, and slips over the lip in the outdrive as the drive comes down into running position. Make sure you don't have one of those before working on replacing it. It doesn't have the corrugations like the regular bellows. You can see it here:
http://www.mercstuff.com/exhaustbellows.htm
If you do have the old style bellows and did pop it off the outdrive leg, then you took a much harder hit than you realize. You'll have to pull the drive to re-attach the bellows, it'd be a good time to double check the outdrive and trim cylinders for damage.
I kind of agree except that the drive side of the bellows will probably not align with the exhaust hole when you trim down and could be crimped and cause back pressure. I think I'd rather see that type of bellows removed then run unattached . . .I've heard of people running with no exhaust bellows, and if I were to switch to the "new style" that is just a tube that seats upon lowering the drive it wouldn't be any different, so I don't see it as an immediate problem to fix.
Scot, the reason "they" don't mark many obstructions, especially natural ones, is that once 'they' assume that duty they could be responsible if they miss one, or a marker disappears. Similarly, boaters would come to rely on them, and have a false sense of safety when they see no markers. Finally, a marker is inherently ambiguous: does it mark a 100' long bar or a piling? So it's up to the captain to know the waters.
(I boat on a coastal wilderness; there is a pole with a big sign: DANGER. Some years it's deep and fast currents there; some years it's a submerged sandbar. The sign itself blew off in recent storms, but it will always be called "the danger pole.")
Security: Scot just missed having passengers injured. Imagine mother in law thrown into the top edge of the windshield, taking out all her teeth. A person in the bow area (or worse, on the bow deck) could be thrown off and under, crushed between hull and obstruction. His exposure is especially increased if the injured is a non-family member, one of the children's friends for example. Even short of injury, a collision like that could require salvage, inclusing hazmats, or search and rescue--possibly at the boater's expense.
We think about collision with other boats as the primary exposure to liability, and perhaps a watersports mishap next, but the "single vessel" is as much at risk. Simply coming into the pier and having a child put an arm out can set you up for a big loss. In an instant.
