boater1234
Master Chief Petty Officer
- Joined
- Jan 6, 2010
- 869
Well i should be getting a brand new 20hp 4stroke merc any day now and was wondering if i need to break it in straight by the book?I thought i saw someone here say you can cut the time in half to like 5hrs instead of 10,is this true?Also i would think all you need to do is vary your rpms up and down and avoid full throttle and idleing for long amounts of time.It just seems 10hrs is way over kill.But if that is what it should be then so be it i may as well go by the book.I have heard from many people who have broken in outboards to just vary the speeds and you need to do it for like one full tank of gas which would be a 6 gallon tank in my case.I need some opinions on this please.Have most of you just varied the speed for like one tank and avoided wot or do most of you go straight by the book?
Also i have seen alot of people just break in their engine at home in a barrel of water,shouldn't you breakin a engine on a loaded boat?I have heard you should weigh the boat down as much as possible to make the motor work a little as that will break it in better,it this true?It's been a long time since i had to break in a engine so i don't want to screw this up and get the best possible performance out of it.
Also the oil that comes from the factory is just good old regular quicksilver oil right?Is it a special breakin oil or will any oil work?I think i want to break mine in with full synthetic oil,i don't think it will hurt it at all.I know it's been a on going thing whether it's safe to use synthetic oil for breakin or not.I can't see how it can hurt it.Also there has been no engine failures i have heard of when breaking in a engine with full synthetic oil or conventional oil so i would think both would be safe to use.
