Whidbey
Thread starter- Joined
- Jul 10, 2012
- 62
Hi All - The boat (22' heavy glass hard top) was set up with a vortec block and non vortec heads and intake when I got it. Found out it had a cracked block and no compression in a few and little in a couple more. So, for the cost I was better off getting a re-manned long block and it's running really good.
Question: The fuel supply was set up with an electric pump, so I tapped and plugged the mechanical pump holes on the new block. Having some issues with fuel delivery to my 4S kicker....it's flooding, because of the way the delivery is set up:
main tank>electric fuel pump>fuel water separator>kicker and 4bb Holley carb....the kicker floods when pump/key is on. It sucks the bulb flat and I suspect it robs everything N of the fuel pump when the key/pump is off but doesn't flood.
My solution:
tank>fuel water separator>fuel pump>holley
tank>fuel water separator>shut off>kicker
I'm not sure the size regarding psi the existing fuel pump is, What should the new 5.7 holley 4bbl have in terms of size for the electric pump. I want to stay electric...recommendations for type?? sierra/walbro...etc...?? Please let me know if my solution is good. I don't want to cause a lean condition in my new motor. Thanks!!
My solution:
